"Do not break in an engine on Synthetic oil!"
http://member.rivernet.com.au/....html
Is that correct? I've always thought that the first thing one should do if they are going to run synthetic is to get the dino-oil out of the motor because you don't want the seals to soak it up. If the seals were to soak up the dino-oil and then you later change to synthetic you'll have leaks everywhere.
So I've always dumped the oil out as soon as I took delivery of the new car and put synthetic in (within 100 miles).
Did I do a bad?
What's wrong about breaking in a new motor with synthetic?
Did I do a bad?
