do you run pump gas with your GIAC 1.1 BAR
606 Views 5 Replies 6 Participants Last post by  wolfsburg2
GIAC 1.1 BAR can it be ran with pump gas or you need race gas?
we have only 92 octane gas here, do you think i can run safely a GIAC 1.1 BAR V.04 chip , It seems to make GOOD power
[Modified by the ambush, 6:59 AM 11-24-2001]
See less See more
1 - 6 of 6 Posts
Re: GIAC 1.1 BAR can it be ran with pump gas or you need race gas? (the ambush)
i have the same chip as you do. here we only have 92 also, and thats what i use. no pinging and no limp modes here. everything works well for me with the 92 octance.
Re: GIAC 1.1 BAR can it be ran with pump gas or you need race gas? (1gti2nv)
That's what I use also. No pinging ever.
92 should be OK. I run 93 most of the time on my GIAC 4 and it will pull back timing during the summer according to my VAG-COM, but it doesn't ping. I see you're in Canada...you should be fine. Heat and humidity here in eastern VA KILL my power in the summer.
Re: GIAC 1.1 BAR can it be ran with pump gas or you need race gas? (dbrowne1)
92 is fine...i use Esso's 92 with my V.04 GIAC.
Re: GIAC 1.1 BAR can it be ran with pump gas or you need race gas? (SL 1.8T)
no probs
1 - 6 of 6 Posts
