I wonder if anyone would turn off the traction control, and why?
Or do you turn it on all the time?
Quote, originally posted by improvius » |
This seems an odd question, since you would always have to turn it OFF rather than turn it ON, since it is always on by default. Anyway, I usually turn mine OFF. -Imp |
Quote » |
The only reason I have it on, is b/c the yellow light gets annoying. But yu are right, I myself also almost got hit b/c my car started braking!!
Quote » |
My traction control (ASR) is turned off via Vag Com. I almost got hit by another car trying to leave a parking lot. My car bogged down when I needed the speed to merge onto traffic. |
Quote, originally posted by 94_Red_Jetta » |
Why? I don't understand. Why would the car started braking if turn it on? So is the traction control a bad thing? Please explain it to me, because this is very new to me. (I just did a test drive, and I turned it on, I have not tried to turn it off, so does it give you better driving experience when it is off?) Thanks. |
Quote, originally posted by me love cars » |
actually, when I think about it... I think it might be some sort of clutch mechanism. I live in CO, where there is snow. I use the ASR in the snow and those really snowy drives where it is constantly being used... when I get home my car smells a little, like a burnt up clutch smell. With the way it works still apply power, but limiting how much, I wouldn't be surprised that it is a clutch-like devise... ... does anyone know? can't find anything on the VW website and don't feel like looking it up in my manual. |
Quote, originally posted by BrandonC » |
ASR (as has been said) can be turned off. EDL can NOT be turned off without pulling fuses or modifying the ABS sensors. EDL does not slow you down like ASR will, so it's best to leave it alone. |
Quote, originally posted by ElectroMike » |
You also have EDL, which cannot be turned off and works under 20/25 mph only, once your above that ASR kicks in. On newer models, ESP added more control over the car and controls all 4 wheels, it incorporates ASR into it's setup and cannot be shut off complete, unless a VAG-COM is used. ![]() |
