1 - 12 of 12 Posts
Re: Does anyone else have this problem? (redsox)
i'm taking a break from replacing my door panels, as we speak. I noticed on mine there was a minor gap, not as big as yours, on the passenger side front door. I just took it off and played with it until it magically went into place. Maybe you don't have something lined up correctly or one of those screws isn't feeding into the whole it's supposed to..hope you have some luck fixing it!
Re: Does anyone else have this problem? (reynolds9000)
I've taken em off at least 3 times. Everything seems like it's lining up okay. It's like that on the driver side too
Also both doors on the Sequoia I had were like that too!!
Maybe I'll try one more time to re-install them.
I would love to know how to alleviate that, except mine is at the bottom of the door. I worked for 1.5 hours several weeks ago to get ti right and still can't get it.
Discussion Starter · #6 ·
Re: Does anyone else have this problem? (don_figueroa)
Quote, originally posted by don_figueroa »
do u have the part number for the clips
Yeah I think so lemme check..........
Discussion Starter · #7 ·
Here ya go buddy: 1HM868243E
Hope that helps ya!
How do you go about removing the door panels completely. I get everything off except for the window crank. What do I do to remove the window crank from the door?
Good luck getting the panels to fit. Hope you don't consider this a hijack of your thread.
Thanks
Jeremy
Discussion Starter · #9 ·
Re: Does anyone else have this problem? (GolfBaller)
Not sure. I gots me some electric jobbies.
You probably have to pry a cover off the crank arm and take out a screw.
Good Luck!
you can see a thick black plastic spacer between the crank and the panel(looks like part of the crank) push that spacer up, and crank will slide right off
Re: Does anyone else have this problem? (putang spangler)
Quote, originally posted by putang spangler »
pull it in the opposite direction from the handle's knob.
yeah, that sounded kinda perverse...
i have a small gap in mine, not that bad, its worse on the passenger side (which is odd because i only have removed the drivers side
1 - 12 of 12 Posts
