Does anyone know what is needed to upgrade from 11.3 to 12.3 brakes?
348 Views 9 Replies 6 Participants Last post by  VAG Parts Bin
like the topic says please reply here or email me
See less See more
1 - 10 of 10 Posts
Re: Does anyone know what is needed to upgrade from 11.3 to 12.3 brakes? (JuiceJetta)
I was told I need the rotors and caliper carriers but I am not too sure about this. I know I need the rotor but not too sure about the caliper part. I was told the carriers from the Audi TT but not too positive.
Re: Does anyone know what is needed to upgrade from 11.3 to 12.3 brakes? (yelowgti)
Aftermarket wheels?
Re: Does anyone know what is needed to upgrade from 11.3 to 12.3 brakes? (shardboy)
quote:[HR][/HR]Aftermarket wheels? [HR][/HR]​
You have to run atleast 16" wheels with TT brakes...
wheels are not the problem i need to know what i need for the brakes.....
thanks anyway guys
See less See more
okay,
here is a list of parts that you need
12.3" tt rotors(2)$120 each
1 set of TT caliper carriers$85 each
1 set of VR6 calipers(used is good)
1 set of new banjo fittings to connect brake lines
1 set of custom spacers(I believe that the spacers are needed because TT rotors are seated differently)
1 set of braid brake lines(optional)
4 liters motul dot 5 brake fluid
I priced this out and I could get a set of Willwood 4 pistons with stock rotor for the same price!
See less See more
Re: Does anyone know what is needed to upgrade from 11.3 to 12.3 brakes? (greengtivr6)
Where do I get the spacers from and where do the spacers go?
I priced this out and I could get a set of Willwood 4 pistons with stock rotor for the same price![HR][/HR]​
See less See more
All that stuff is correct for the install...I was just looking on www.parts4vws.com and potter has done some updates - one of which is a listing for a TT brake upgrade - same thing you're interested in. Check it out, or better yet, call them to find out the specifics. Good luck. Oh by the way...wilwoods would be awesome too, but I'm pretty sure they have to be rebuilt every year or so. It's all a matter of personal taste - you'll be happy with either setup I'm sure. http://****************.com/smile/emthup.gif
See less See more
Re: Does anyone know what is needed to upgrade from 11.3 to 12.3 brakes? (am1899)
I am checking out them now
thanks http://****************.com/smile/emthup.gif
See less See more
2
If you already have 11.3" brakes all you need is:
- Audi TT/S3 carriers
- Audi TT/S3/4-motion 12.3" rotors
- New pads
Calipers are the same. Brake lines are the same since you already have 11.3" on the car and the 12.3" kits use the 11.3" caliper setup. No spacers unless you need them for a certain wheel to clear or something - out of the box you should be ok.
1 - 10 of 10 Posts
