1 - 8 of 8 Posts
Re: Does anyone run 205/50/17s on 17"Classix? (kerosenec4)
Running stretched tires in the winter would be somewhat of a stupid move... You want to have the maximum amount of tread area possible in order to improve traction. I realise that the difference in tire width is minimal, but every square inch counts.
It's winter, safety first; especially if you're carrying any special cargo.
Re: Does anyone run 205/50/17s on 17"Classix? (david8814)
Actually, I think it's better to run narrower tires in winter. This gives the contact patch a higher pressure (force divided by area), which will enable the tires to "push" through the snow and grab the pavement. Wider tires tend to "float" on the snow.
I'm looking at running the same setup when winter comes.
Internet Lighting Police
Incorrect....
Quote, originally posted by david8814 »
Narrower tire - taller sidewall = better in snow....
Re: Incorrect.... (cb1111)
Quote, originally posted by cb1111 »
Makes sense... I didn't really consider snow (don't get much here in beautiful Raincouver
). Only real problem here is ice, and wider=better in that regard. Guess the OP has to consider snow where he's at haha.
1 - 8 of 8 Posts
