21 - 32 of 32 Posts
Re: "Dogbone Mount" Bushings....Are They *Really* Worth Changing?? (KJ-VR6)
and 4
and voila!
add: the ones inside the mount are easy to take out.. hard to get back together. the circle one: just beat it out! there is no easy way to get that thing out. use WD-40 or my fav: Prolong SPL100.
[Modified by 1BadAzzVR6, 11:08 PM 4-7-2002]
Re: "Dogbone Mount" Bushings....Are They *Really* Worth Changing?? (1BadAzzVR6)
KJ....easy as 1,2,3.....itll take us like 10-15 min. tops to do this, i did it in the dirt w/ ghetto jack and wood supports lol...in 15 min. order up ill do it for
quote:[HR][/HR]Ahhh..so it is as easy as "1 2 3" ? Hmmm...only $16 for all three of these from ES huh? http://****************.com/smile/emthup.gif Or is it a bitch getting the black ones out?
[Modified by KJ-VR6, 2:09 AM 4-8-2002][HR][/HR]​
Took me all of 30 minutes to install them. Its not hard at all. Just do it, its only $16 is you dont like them take them out and let you dog use them as a chew toy.
Re: "Dogbone Mount" Bushings....Are They *Really* Worth Changing?? (2kjettaguy)
quote:[HR][/HR]The Z mount is too rough for daily driving IMO, though on the track it performs excellent. I am using the vw motorsport mount. Its a full replacement and cost a bit, but i think its totally classy. Its way stiffer then stock, gives a slight increase in vibration in the cabin, but keeps the engine in place. Especially with the extra bit oftorque I have now
[HR][/HR]​
I have been looking for this. I found a place a while back, but they don't carry it anymore. Do you know where I can get one and 'bout how much are they?
I have a Z-Engineering mount and I drive my car every day and it doesn't bother me. It actually does have hard bushings at each end. The car is a little more rough than stock, but it's no problem. I think most of you are sissys, just go buy Cadillacs.
KJ-VR6,
Which part numbers did you just order? Are they the same for the 1.8T? I want to get some stiffer rubber in there but I am not sure which ones to get. Thanks.
I'll second the vote for the VW Motorsport mounts. They usually retail for $150. Keep in mind that it isn't just bushings you are getting. You are getting completely new and stronger mounts!!! Wheelhop is gone with these and there are no harsh vibrations.
Re: "Dogbone Mount" Bushings....Are They *Really* Worth Changing?? (adg44)
quote:[HR][/HR]
I heard the VWMS mount is exactly like stock, but just with stiffer rubber??[HR][/HR]​
Yep. I have a VWMS mount. Glad I bought it. http://****************.com/smile/emthup.gif It replaces the entire stock mount, metal parts and all.
Just make sure you use new stretch bolts when re-installing the mount.
Re: "Dogbone Mount" Bushings....Are They *Really* Worth Changing?? (Max Rebo)
That's wierd, the ES dogbone inserts I have are black not red. I think black = graphite impregnated to eliminate squeeks. Red = ???
You won't regret it though, I was concerned about vibration and only had #1 and #3 installed. After a few miles, I realized I wanted it "tighter" and the vibration was almost non-existent so I had #2 installed as well.
The whole front end feels way more solid, shifting is greatly improved and wheel hop is greatly reduced. All with next to no vibration. Best CDN$25 I've ever spent on a car.
21 - 32 of 32 Posts
