1 - 4 of 4 Posts
so i got all of the bolts off, even the one on the rotor....but how do i swing the caliper up, to remove the rotor? any help??
Re: doin a brake job...need some serious help (DUBdiddy)
If you have all the bolts off, you should be able to pull the caliper off as well as the bracket...
Re: doin a brake job...need some serious help (shardboy)
Yup just two bolts on back of caliper that hold it to the hub ...if those are out you should be able to pull it right off....it just needs a little coaxing.
1 - 4 of 4 Posts
