1 - 11 of 11 Posts
Hi guys, haven't posted for a while, but I had a quick question. Some friends and I are thinking about picking up a small cheapish trailer for a road trip this summer, and since they all drive honda and toyota sedans, my tig is the de facto tow vehicle. Has anyone tried towing a small single or double axle trailer? Am I really limited to only 2,500 lbs? I remember reading somewhere that the towing capacity was higher for euro tigs with the 2.0TSI.
Let me know if you have any thoughts
yeah I've towed a 5x8 single axle trailer loaded with concrete, three trees, tons of crap multiple times. No problems. i don't think ive exceeded 2k pounds, and my local dumb is not far. Car never hesitated though!
I haven't done any towing lately but I plan to soon. My 2012 has the factory hitch and 7pin plug. I have an adapter for the 7pin so will be testing it soon.
The factory hitch has a 1-1/4" receiver. From what I have read this size receiver is only rated for 2000 lb. I expect I will be towing around 2500 pounds, for fairly short distances; 15-20 miles per trip, each way.
Should I be concerned about the hitch rating? Should I abandon the factory hitch and install a 2" / class III receiver?
Any advice appreciated.
I tow an 8" popup with my Tig and it's like it's not even there. I did get a 2" hitch box, and had the trailer module installed at my dealer (it has active anti-sway, alarm connectivity, and more - it's not just lights). If you already have the tow package installed, it's cheap and easy to upgrade to a 2" box (I got mine at etrailer).
Thanks for the info. I will probably do that too. Did the 2" receiver have a place to mount the 7-pin connector? The factory one has a plate that bolts to the receiver and I'm wondering if the one from etrailer has that too.
I've towed a 500lb trailer with ~500 crap on it 420 miles round trip several times now. There is plenty of torque for towing so thats not a big deal even here in the utah/idaho mountains. Going heavier than the rated 2200lbs i wouldn't worry about the power, but i definitely would start worrying about the braking if the the trailer doesn't have its own brake setup. these tigs are only 3400-ish pounds, towing something that starts approaching 2/3 of your vehicle weight without additional braking starts getting scary in my book.
that said - if you' really not taking it at highway speeds and only short trips, i'd totally do it and just be really careful about not having to stop short
Yes, thanks for that link - I used it when figuring out my own set up. I basically used 2 pieces of strap bent in an L shape, one part of the L on each side of the 7-pin, the other bolted to the plastic of the bumper cover underneath.
I figure the connector is pretty light and the bumper cover is pretty strong.....used stainless hardware and nylock nuts. Will probably paint the bracket as it is a bit bright.
Mark
The tig's braks are actually quite beefy... that was my torture thread, 5000+ lbs for over 1000 miles from phoenix to Florida....no problems.....
1 - 11 of 11 Posts
