1 - 3 of 3 Posts
Rear Parking Lights
My rear parking lights will not go on for some reason.
Does anyone know what this problem could be? I checked the fuses and made sure that the wires didn't fall out. Could all the parking bulbs blow in the back at the same time? I figure its the wiring.
-Pete
Why dosn't the title of a post change when when you edit it?
Modified by Sculls84 at 1:05 AM 2-17-2004
Modified by Sculls84 at 1:07 AM 2-17-2004
Re: Rear Parking Lights (Sculls84)
Well, check the bulbs first in case. Otherwise, it could well be your headlight switch or the harness from front to back. There are also some fuses above the fuse panel that do different things. I was mystified once what was going on and then noticed a blown fuse that even melted its housing up above.
1 - 3 of 3 Posts
