Hey, I'm at school at UW Madison at the moment but my 84 Jetta is back home in Ohio. When I went home over spring break the car wouldn't start, after jumping it, it would start then I'd drive around for a while and it would start fine the next day. This is a new battery, (got it on winter break after Autozone said the old one was bad) and I replaced the cable from the starter to the alternator over winter break because it was bare in a few spots.
So this sounds like there's some sort of draw on the battery, right? how exactly does one check for where it's coming from? I swapped in a 1.8L in place of the 1.7 last summer and one thing I didn't do was reconnect the cold start valve (lazy, I have the connector around there somewhere) is it possible that this is causing the drain? I also have some speakers powered by a small amp in the back, but it hasn't been working (maybe because of my poor wiring job in connecting the wires). Basically I hate electrical stuff and any help I could get in narrowing the problem down would be helpful before I go home next month. Oh one other thing, my radiator fan hasn't worked for a pretty long time either and it works on direct power and I did get a new switch, though it could be bad. Sorry about the length Thanks.
