My car is a 1988 Scirocco with a 1.8 16V engine.
Lately the car developed and intermitent "sputtering" problem. This morning on my way to work it got worst. When starting from a dead stop the car would start jerking back and forth like a wild horse the revs will bounce from 1,000 to 2,000 and the car will barely have any power. If I press the clutch an rev the engine without any load it will rev normally, the jerking only appears when the engine is under load. This jerking will stay throught all gears, the car will run, but alway jerking and underpowered. Then, suddenly, the car will start running like nothing was wrong with plenty of power. A few minutes later the sputtering will come back. What could be causing this?
The car is mostly stock with the exception of a TT header and cat and a set of Autotech street cams. T-Belt was recently done as well as spark plugs, cap, rotor.
TIA
TIA
