1 - 4 of 4 Posts
I have a MK4 Jetta and suddenly all the driver door buttons and the headlight switch have their backlights stuck and won't turn off. All the other button backlights turns on and off depending if the headlights are on or off, but these I mentioned, won't. Even when the car is off and locked, headlight switch off, from outside I can see the button backlight stuck on.
I uploaded some photos:
Any ideas?
Classical MK4, electrical gremlins.
You may want to remove the headlight switch and inspect for any wiring or anything odd
Discussion Starter · #4 ·
I've removed the headlight switch but as far as I could see, everything is in place.
Also check the ignition switch. If it is malfunctioning it could be part of the problem.
Nothing wrong... But tonight I just noticed that the headlights switch backlight just turned off, I don't know when this happened, but the door buttons backlight are still on, even with the headlight switch at off.
1 - 4 of 4 Posts
