1 - 2 of 2 Posts
Hi my driver door got stuck, couldn't open from the outside but could open from inside. I went and read a few forums and they told me to adjust the plastic lug that has a wire connected to it that is attached to the module. It might be tight so I had to loosen it a bit, In the process it fell inside the door and not only did it not fix the problem but I cant seem to find any other way to get inside to find it. Can you please help with any suggestions or ideas? Thanx
1 - 2 of 2 Posts
