Hope this helps
Well just repaired the voltage wires in the door harness, piss poos design (no stress relief and should of used silicone coated wire) but that another story! Pulled the outer shin did my modifications and worked great!!! Buttoned it all up, one last check...window
...fuel door
trunk
... remote locks
... unlock
... open the door ... open the door ....
@#%%@&*. After reading this thread and was not going to pull the door again, but I did pull the key assembly and handle. Looking inside I could see where the cable was attached and did not see anything that would cause it to bind. Closed the door pulled the cable it opened. After playing with it for 20 min... WOW really
So when I put the plastic cable nipple back in the handle I pulled it, and inserted towards me (tension on the cable). Re-installed the handle and just seated the plastic nipple into the handle ...No Tension!! The only thing I can think of is, the throw on the power locks must bind something inside, however it's released when the inside handle is used (until you lock it again :screwy
So Release the key assembly set screw, remove the assembly, remove the plastic nipple from handle, re-install nipple (No tension!!!). Re-install key assy and tighten set screw Let me know if that helps.
