I test drove a WRX, RSX-S, IS 300, and a 24v VR6 GTI recently and thought I'd share my impressions of each.
WRX: Interior was ok, but definately not a high point of the car. Worst of the group, although that shouldn't surprise. The turbo was decent, but didn't wow me either. Spool up was pretty quick as long as you stayed above 1200 rpm. There were a couple of times when I got caught off boost below 1200 and the car barely felt like it was accelerating. Power starts to taper off after 5000 rpm. Steering feel was somewhat numb (compared with my '98 Jetta), but acceptable. The shifter right out sucked. Short, but sloppy throws and is NOT weighted. It felt like I could rip the shift lever right off the car I tried. Pedals had a light feeling to them, but they were set up perfectly for heel-toe. Handling was somewhat soft, but with the all wheel drive you could coax the car into a drift with ease. I felt like with a little more time behind the wheel I could've screamed around some corners. My biggest complaint of the car was the car's behavior when shifting while in the throttle. It seemed to cough/bog a bit as I shifted. Perhaps one could learn to shift smoother after driving the car over time. The car stickered at 24+ k which wasn't worth it in my eyes. Of course the ability to mod the car is the kicker. I might have a different opinion had I driven one with mods.
RSX-S: A big disappointment here. I didn't care for the engine note, nor the power band. It pulled somewhat better in the VTEC zone, but it seemed like it the power delivery wasn't that smooth up there. Being that it was a test drive, I didn't shift any higher than 7500 rpm. Would you believe the saleman proceeded to lecture me about shifting at redline (even though I was 1000 shy of it)? "If you hit a bump, the car will spin past redline and throw a rod". Whatever. Handling was pretty good, but there was that subtle Honda numbness about it. Pedals weren't ideal for heel-toe, but you could do it with practice. I really can't believe C&D got 6.1 0-60 out of one. The RSX-S stickered at 23+ K. Maybe a fully broken in car is faster, but I came away unimpressed. http://****************.com/smile/emthdown.gif
IS300: Nice. 5-speed Manual shifted without much slop, pedals had a firm substantial feel to them. Not set-up for heel toe unfortunately. The engine had a great BMW straight six sound to it, linear power delivery, decent torque, but it felt like it needed an extra 30 hp/ft-lbs to be fun. The handling/ride was near perfect. The car felt completely flat. I could feel every bump in the road, but not too much (not bone jarring ride here). The steering had a great feel to it as well. I drove a stripper which stickered at ...(get this) ... 30K and change. Damn! Imagine a new BMW 3-series between the 325 and 330. That's exactly what this car felt like. Up the power by 30, drop the price by 5k, and I'd be all over this!
2003 24v VR6 GTI:
The engine is much more quiet than the 12v. Very nice power delivery. Did I mention the torque? Cruise along in any gear and punch it .... the car pulls like a banshee all the way (and past) redline. It felt like a 6 with a light pressure turbo. The engine did however have its quirks. It seemed like rowing through the gears that the car didn't want to accelerate as fast as if you punched it mid gear (and let off). Especially when shifting gears, it felt like the ECU had to figure out that you wanted max power each time you shifted. Even then it still didn't seem to want to accelerate as fast as it did doing mid gear punches. Oh yeah, did I mention the throttle response absolutely, positively sucked? There is at least a .3 second pause between the time you push the pedal and when the car responds. I truely believe that the biggest benefit of chip tuning will be throttle response. Those mid gear punches felt like a mid 14 second car to me. I think the GIAC chip will do a lot for this car. Stickered at 23k+, this would be my choice of the group. Handling, steering feel was typical of an MK4. Pedals were not set up for heel toe either.
Graff
2003 24v VR6 GTI:
Graff
