Re: (Kid Hobo)
you'll find that accurate gauges are less common than you would think. Water temp gauges with H and C, gauges that don't move much unless something is VERY wrong as to lessen the number of dumbfounded car owners who call roadside assist because their oil pressure needle moved from 12 o'clock. Most tachs, speedometers, you name it, are not only inaccurate but also very slow to update. Watch your tach at each DSG shift and compare that to what you hear the motor doing - the tach lags a little even with the quick DSG shifting. Panic stop from 45mph and your speedometer is still falling after the car is static.
Modified by WetWagen at 10:43 PM 3-20-2008
