1 - 5 of 5 Posts
AWP engine code ... 06A 906 032 LP ... running APR Stage 3 ... 93 oct program.
Pulled these codes off my car tonight:
16684 - Random/Multiple Cylinder Misfire Detected - P0300 - 35-10 --- Intermittent
16688 - Cylinder 4 Misfire Detected - P0304 - 35-10 --- Intermittent
16686 - Cylinder 2 Misfire Detected - P0302 - 35-10 --- Intermittent
Coilpacks in 2 and 4, right?
Bummer, 'cos I replaced all my "H" packs with "L" packs about 5 months ago. Any ideas?
Re: DTC help requested (chaugner)
Quote, originally posted by chaugner »
do they come back right away after you clear them?
I haven't driven the car since pulling the codes, but just turning the car on and giving it a quick blip to about 2500-3000 rpm does *NOT* reproduce the codes.
If not get new plugs
Not challenging your recommendation, just curious: why should I get new plugs, rather than new coilpacks?
Thanks http://****************.com/smile/emthup.gif
Re: DTC help requested (moclov)
misfires can be caused by old/bad plugs. If there was a problem with coil packs the problem would come back right away.
just get some BKR7E's , gap them a little closer and see if it comes back
1 - 5 of 5 Posts
