1 - 5 of 5 Posts
Underground VWparts is installing a VR6 dual fan setup, I'm planning a similar swap, I wanna put a dual-fan rad from a MKII GTI in my cabby, has anyone done this, with or without the engine swap?
Just wondering if you have any advice.
Re: Dual Rad fans (Spinyfrog)
I wasn't aware the A2 GTI came with dual radiator fans. However, I do know that many people fit the A2 radiator into the A1 cars, so it would stand to reason that an A2 fan has a good chance of fitting as well.
I have also read that someone fitted the dual fans from a Porsche 944 to his Rabbit pickup, so it is possible. Other sources for dual fan assemblies include the B3 Passat and the Audi 4000.
Good luck with it.
Re: Dual Rad fans (Kevin Rowley)
I know a local guy who fitted the vr6 dual fan on a 2 8V liter cabby. It was having problems with getting a bit warm..
Here is what you want unless you can get one cheaper. They installed one of these in one of Eurotuner's Project Scirocco. Seemed like very easy install. Also you can wire the fan to either pull or push air.
Scirocco Dual Rad Fan
Modified by Fst'N'Frs at 9:44 PM 7-3-2003
1 - 5 of 5 Posts
