this is a preventative maintainance suggestion ...
all m.y. 2000 & 2001 & early 2002 (1st qtr) 1.8T engines are very likely to have the early dual temp sensor (located in rad hose/manifold at #4 cyl end of cylinder head) ... early sensor is Black (simply remove electrical connector to determine colour) ... several functions - important function is "idle mixture enrichment" ...
the revised "Green" sensor P.N. 059 919 501A will correct excessive idle enrichment & high idle rpm (cold start) ... O-Ring seal is P.N. N 903 168 02 ... Resin Retaining Clip is P.N. 032 121 142 ...
total cost outside n.a. is approx $35 usd - remember this sender (sensor) is used on all 1.8T engines (think audi/vw/seat) ... in usa dealers are offering at discounted price to car owners ...
this info has been posted by others over past 4 months ... it is useful to remind again ... "Green" sensor will solve some of your problems ...
on some engines, resin manifold will also have aircon temp sensor - this is "Gray" colour - you are interested in "Black" or "Green" sensors ...
remove air box cover (& air filter) for easy access to end of cylinder head - sensor is at lower edge of head casting in resin manifold ...
Modified by kwokTTQ at 3:17 AM 5-25-2003
