1 - 5 of 5 Posts
Howdy, thought perhaps one of you guys might have had this problem before.
My Dummy brake light won't turn off. It turns on with the ignition, and simply won't go off. The ABS turns off, as with the Check engine light...but the Brake light WILL NOT go off.
I've already checked the brake fluid level. (which is fine, apparently, if it's low, the light will come on and stay on)
I've ruled out the fact that it could be an ABS problem as the ABS works fine( I checked
and the ABS light goes out as normal)
I've taken out the center console to look at the brake lever actuator and tried to see if the switch at the brake lever is fried or not connecting. HOwever, it can't possibly be fried, as it's no switch at all. IT simply breaks a loop when you push down the parking brake. When you have the parking brake on, a spring pushes a powered connector back up and grounds out against the chassis thus turning on the light. If this hasn't made any sense, or if you have any ideas, please let me know...the light sorta bugs me.
Cheerz
Re: Dummy Brake light won't go out (Gerapudo)
quote:[HR][/HR]unplug it the light![HR][/HR]​
good english.
Anyway, free bump cause I have the same problem. The light is always on, but when you pull the parking brake it gets brighter. my mechanic said it must have a bare wire exposure somewhere causing a current to go through it. i dunno, he is too lazy to actually fix it.
Discussion Starter · #4 ·
Re: Dummy Brake light won't go out (DaveNY)
Mine won't actually get any brighter if I pull the parking brake. It just stays the same...no difference whatsoever. It's as if something it not connecting telling the light that the parking brake is off. I just can't figure out what it is...
Oh, concerning just pull the plug to the light. If I did that, I'd pull the plug to the entire set of dummy lights. Check engine, ABS, and the brake light...which I might resort to if I can't fix it, but still, I'd like to fix it if I can. Anyways, thanks for the input.
Cheerz
· Banned
good english.
Anyway, free bump cause I have the same problem. The light is always on, but when you pull the parking brake it gets brighter. my mechanic said it must have a bare wire exposure somewhere causing a current to go through it. i dunno, he is too lazy to actually fix it.[HR][/HR]​
Wat you talkin bout willis?
1 - 5 of 5 Posts
