dying 24v - Electrical problem and misfire
So about 2 weeks ago I was on the way to school and felt my car bog down and buck. It only did it once and went back to normal so I did not think much of it. Later that day after I had come back home, I was again heading back to school for another class and when I felt the same thing. Bogged down, bucked, started to shutter, and sounded absolutely horrible. The check engine light also started flashing when the engine was under load so I figured it was a coilpack or spark plug. Next day I narrow this misfire down to cyl. 4 easily in between classes. By this time when I would drive the car all I could smell is fuel. Could smell it in the car, outside the car, and for awhile after it was shut off. Went ahead and changed the coil packs around and still cyl. 4. Put a new spark plug in and it does not work.
So I take the other 5 that I have at home a through them in just to amuse myself. Still the same misfire in cyl. 4. Put the new coil in cyl. 4 for the hell of it and nothing. Put all the old stuff back in with no positive or negative results. So then I figured it seemed to be a fueling issue with the injector for cyl. 4. I changed out the fuel filter for the first time on this car and ran a high concentration of fuel injector/fuel system clearner in hope that may help clean the fuel system if there was some junk in there. Nothing. So the next morning I took it apart to see what the hell was going on. From the searching I did on here there was a possibility that the o-rings that seal the injector to the head could have gone bad on that injector in cyl. 4. I was hoping this may be the problem because I didn't want to buy a new injector. hahah.
When I took it all apart I replaced all the vacume lines that were in any type of bad shape, replaced the intake manifold gasket because it was being removed, replaced the rubber o-rings on the number 4 cylinder, put all the new spark plugs in, and a new coil for cylinder 5 because of a melt down.
Got it all back together Friday night of last week after waiting for parts through the week. Started it up and it ran great. Took it down a couple blocks and back just for the text drive after everything was apart. So I was back to driving it. Then yesterday(Monday) comes along and im on the way back to one of my classes and what happens?
Same thing as before. I got two days out of it before the same symptoms cam back. Also have went through most of the same diagnosing procedures.
My next steps are to check the alternator to see how much power it is putting out and make sure its the right amount, check battery to see if it has boiled over, and check the voltage regulator. Below is the read out from Vag com.
VCDS Version: Release 908.1
Data version: 20091018
Monday,01,February,2010,15:45:09:45947
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
VIN: 9BWDH61J934021159 Mileage: 152180km/94560miles
Address 01: Engine Labels: None
Part No: 022 906 032 CS
Component: 2.8-LEV-Mj03 G 1482
Coding: 00032
Shop #: WSC 09416
9BWDH6xxxxxxxxxxx VWZ7Z0B5350981
12 Faults Found:
16588 - Injector: Cylinder 4 (N33): Circuit Malfunction
P0204 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16688 - Cylinder 4: Misfire Detected
P0304 - 35-00 - -
17778 - Cylinder 6 Ignition Circuit: Open Circuit
P1370 - 35-10 - - - Intermittent
17775 - Cylinder 5 Ignition Circuit: Open Circuit
P1367 - 35-10 - - - Intermittent
17772 - Cylinder 4 Ignition Circuit: Open Circuit
P1364 - 35-10 - - - Intermittent
17769 - Cylinder 3 Ignition Circuit: Open Circuit
P1361 - 35-10 - - - Intermittent
17766 - Cylinder 2 Ignition Circuit: Open Circuit
P1358 - 35-10 - - - Intermittent
17763 - Cylinder 1 Ignition Circuit: Open Circuit
P1355 - 35-10 - - - Intermittent
16497 - Intake Air Temp. Sensor (G42): Signal too High
P0113 - 35-10 - - - Intermittent
16589 - Injector: Cylinder 5 (N83): Circuit Malfunction
P0205 - 35-00 - -
16689 - Cylinder 5: Misfire Detected
P0305 - 35-00 - -
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019970
Shop #: WSC 00000 785 00200
4 Faults Found:
00778 - Steering Angle Sensor (G85)
004 - No Signal/Communication - Intermittent
01314 - Engine Control Module
00668 - Supply Voltage Terminal 30
008 - Implausible Signal - Intermittent
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 F
Component: 08 AIRBAG VW61 0202 0001
Coding: 12344
Shop #: WSC 00000
No fault code found.
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 926 F
Component: KOMBI+WEGFAHRSP VDO V07
Coding: 07234
Shop #: WSC 00000
9BWDH61J934021159 VWZ7Z0B5350981
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00000
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 8B Komfortgerát HLO 0003
Coding: 00064
Shop #: WSC 00000
Part No: 1C1959801A
Component: 8B Tõrsteuer.FS KLO 0002
Part No: 1C1959802A
Component: 8B Tõrsteuer.BF KLO 0002
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 3B7 035 180
Component: Radio 001 0010
Coding: 00031
Shop #: WSC 00000
End ---------------------------------------------------------------------
If anyone has experienced or has any helpfully input please post up and let me know. Remember though that the number 5 coilpack is brand new along with all the spark plugs and it has the same open circuit intermittent code as the rest of the old coils. Makes me think the coils are fine and that it is something else. Let me know.
to you for reading this. http://****************.com/smile/emthup.gif
Modified by VR6VDub172 at 6:31 PM 2-2-2010-
Modified by VR6VDub172 at 5:43 PM 4-8-2010
76
Coding: 00032
Shop #: WSC 09416
12 Faults Found:
P0300 - 35-00 - -
P0304 - 35-00 - -
P0205 - 35-00 - -
P0305 - 35-00 - -
Coding: 0019970
4 Faults Found:
Coding: 12344
Shop #: WSC 00000
Coding: 07234
Shop #: WSC 00000
Coding: 00006
Shop #: WSC 00000
Coding: 00064
Shop #: WSC 00000
Part No: 1C1959801A
Part No: 1C1959802A
Coding: 00031
Shop #: WSC 00000
