1 - 3 of 3 Posts
FS :Fully built FSi cylinder head . Had this head built last year for my Audi and I ended up building a second one with solid lifter and custom cams . List of what’s done to it bellow :
Cnc ported and polished .
Flap notches filled
Cnc machined for the bigger springs to fit
Combustion chamber was polished/ smoothed out also .
Resurfaced
Parts installed :
•Cat cams 762006 cams (biggest cam available in the market for the FSI )
•16x Cat cams upper retainer 99545/s
•16x Cat cams lower retainer 99546/O
•16x Cat cams outer valve spring PAC-E99865
•16x Cat cams inner valve spring PAC-I99865
•8x Supertech inconel +1mm exhaust valves
•8x Supertech +1 intake valves
•16x IE valve guides
•16x Oem valve seals
• Arp girdle bolts
Head is assembled and good to go to a new home I kept it as a back up in case something went wrong with the new setup until I fired it up .
Price is $3500 with the cams that alone cost $1000 . Everything is new and has 0 miles on it .
1 - 3 of 3 Posts
