I bought a 4 headlamp grille on eBay for my '85 Cabby. (And then I found an OEM headlight switch there!) The lights say E1 and take H3s, yet to be purchased. So, how would you set it up? Do I need relays if I just use 55 watters? The stock setup is 4 fuses (hi/lo, L/R) and no relays.
I wonder how the stock 88 - on Cabby is set up. Are the driving lights on their own switch and work only with low beams? As far as I can tell from my Bentley's, they don't have relays either.
Not sure whether to go with yellow fogs or white driving lights. Truth be told I don't drive my Cabby in a whole lot of bad weather or darkness. (MN = 16 hours of daylight or lethal windchill) So I really don't need a trick (uh, hi $) setup.
And oh yeah - I don't have the connectors. Can these be purchased or do you have a good way to kluge them?
TIA
Matt
85 Cabby (in the barn)
00 Astro family truckster
[Modified by MN Cabby, 3:05 AM 12-1-2001]
TIA
Matt
