Easiest instructions on doing the rear fog mod.
783 Views 14 Replies 8 Participants Last post by  Sebeck1
I would like to do this soon, and just want to know for your own experiences which one is the easiest! Thanx vortex people!
See less See more
1 - 15 of 15 Posts
Re: Easiest instructions on doing the rear fog mod. (Jetta97GT)
It's easy, very easy. I even hear that Jettas are even easier than GTI's. I did mine couple of days ago and I thought it was quite complicated before I started. Once you read the instructions carefully and look at the taillight assembly and all you'll figure it out easily. It's not that hard.
Re: Easiest instructions on doing the rear fog mod. (NightRyder97)
For post '95 cars.... http://members.home.com/felixtff/jettarearfog.htm
For '95 and earlier.... http://www.roadrallysport.com/prjctvnto.htm
It is very easy in the Jetta since you do not have to re-wire the tail light assemblies. If you have a '95 or earlier it is cake...
Sean
Re: Easiest instructions on doing the rear fog mod. (EuroStyle)
what connectors and stuff do i get? I need part numbers?
How do i know if my car has the rear fog light indicator light in the cluster? that would be DOPE
When i hooked up my rear fog, all i needed was some wire, some butt connectors (get at radio shack, etc), and a VW wire connector...just search through old threads, i remember posting something last week about this same topic with a link that had a part # for the wire connector
[Modified by VR6 Mk3, 10:00 AM 11-24-2001]
2
you dont need any connectors
just ghetto strip the wire and shove it into the connectors!
See less See more
2
Re: Easiest instructions on doing the rear fog mod. (Gaki)
[HR][/HR]​
Yeah, i did that in the back, it works too...i work at a VW dealership and i was picking up another part, so i got the connector at the same time to do the front when i got my euro switch
See less See more
Re: Easiest instructions on doing the rear fog mod. (SLC PUNK)
there was a thread on this in like the last few days...do a search, i think it was in the golf/jetta 3 area...you need to move the bulbs around and stuff, someone posted a good link
Re: Easiest instructions on doing the rear fog mod. (VR6 Mk3)
You should get the VW connector, it is only $2 (VW P/N 000-979-133-A ) and makes for a factory install that will not give you a headache down the road (like if the ghetto wire slips out...). The cluster icon is only in post '97 cars as far as I know....
Chris, here is a link to the Golf rear fog.... Steve P's How To
And a second..... A Second One.....
Sean
[Modified by EuroStyle, 12:35 PM 11-24-2001]
3
quote:[HR][/HR]...The cluster icon is only in post '97 cars as far as I know....[HR][/HR]​
http://****************.com/smile/emthdown.gif
I keep getting shafted...first no glove box, now this!
See less See more
how do u do the rear fog icon in the jetta, is it the same thing as the golf?
2
oh.. btw, if youre too cheap to buy a bulb for the rear fog icon,
pull the bulb from the seatbelt socket
I found that light to be highly annoying
oh and yes, i wear my seatbelt.
[Modified by Gaki, 4:25 PM 11-24-2001]
See less See more
Try this link for Jettas: http://www.roadrallysport.com/rrfoglgt.htm
I installed my Euro switch and rear fog mod today. It didnt take long at all. The hardest part is running the wires.
See less See more
Re: Easiest instructions on doing the rear fog mod. (ja)
ive had my jetta for 2 years now, and this is one of the best mods...man i got to step up and do this asap
See less See more
quote:[HR][/HR]I keep getting shafted...first no glove box, now this![HR][/HR]​
My girlfriend freaked when we testdrove a '96 GL with no glovebox. The owners manual and stuff were in the passenger door compartment. I ended up getting a '98. It has a glovebox.
See less See more
1 - 15 of 15 Posts
