Used kit for 5k miles or so. Functional condition. No dents/dings from impairing it. Sets the stock wheels flush (Cadiz / Pretoria).
$140 Shipped CONUS (Paypal add 3% or send via friends/family)
Kit includes:
70mm Wheel Studs (20)
17mm Ball Seat Lug Nuts (20)
10mm ECS Front Spacers
17.5mm ECS Rear Spacers
This gives you permanent wheel hangers and saves you time! Simply screw in the supplied studs and you are in business.
Why use wheel studs instead of wheel bolts?
Because, race car.
Wheel studs are required by many racing bodies because they are a safer way to ensure proper wheel-to-hub contact.
Wheel studs allow the use of different length spacers. Lug bolts require custom lengths per spacer application.
Installing wheels using wheel studs is much easier than using wheel bolts, as the studs will locate the wheel while the nuts secure the wheel.
Wheel studs stay in the hub. The constant installation and removal of wheel bolts can cause accelerated wear on the bolt holes in the hubs.
*Note: Thread-locking compound is recommended during installation. Studs should be torqued to 15Nm.
Pix to follow soon.
Kit includes:
Because, race car.
Pix to follow soon.
