New from ECS is the Billet Rear Sway Bar Mounting Kit for your VW equipped with Independent Rear Suspension. These mounts are made from high-quality billet aluminum and are accompanied by urethane bushings for maximum effectiveness of your sway bar function.
vw_sway_mounts_billet_aluminum
Billet aluminum mounting brackets encasing polyurethane designed to fit 21mm sway bars up to 25mm sway bars are not only more attractive than the factory mounting brackets and bushings but are sturdier and longer lived. The billet construction allows for less play and improves the effectiveness of the urethane bushings.
vw_sway_mounts_polyurethane
With stiffer bushings working harder, you are able to notice a drastic difference in sway bar function, which will decrease body roll and increase your grip through corners.
vw_sway_mounts_billet_aluminum_installed_close_up
Since these bushings are polyurethane, they also are greased through the nipple on the sway mount itself. This means a longer life for your bushings, and no more dabbing grease from your fingers on the mounts, or uninstalling the mounts, for applying lubricant.
vw_sway_mounts_billet_aluminum_top_view
Fitment:
For models with Independent Rear Suspension (IRS) Only
VW Beetle (2012+)
VW CC (2009-2017)
VW EOS (2007+)
VW MK5 Rabbit/GTI/R32/Jetta (2006-2010)
VW MK6 Golf/GTI/Golf R (2010-2014)
VW MK6 Jetta Sedan (2011+)
VW MK7 Golf 1.8T/GTI/R/Alltrack (2015+)
VW B6/B7 Passat (2006+)
VW Tiguan (2009+)
Shop Part Number ES3438551
