If your original plastic shifter cable end links are leaving you with a soft, mushy shifter feel and aren't up to the task of continuous, fast gear changes, it may be time for an upgrade. Our in-house engineering team set out to replace the inferior OEM plastic end links with a pair of billet aluminum shifter bodies & bronze shifter inserts for greater confidence inconsistent, rapid gear changes.
Made from 6061 billet aluminum and includes 932 bronze inserts our end links, they are easy to install and adjust and feature seamless bodies once installed.
All parts of this kit are designed and engineered in house at our Wadsworth, Ohio facility and are made right here in the U.S.A.!
Easy to Adjust
Click HERE to order or for more information
Fits:
VW (1999.5+) Transverse 5 & 6 speed Manual
(Check Installation PDF to verify fitment)
Be sure to check out our -----> Installation PDF <-----
Let me know if you have any questions.
Jason
