VW MK6 Golf Double Apex Port Controls -
Add functionality to your dummy switches with Double Apex. The switch design and lighting seamlessly mesh with your VW's interior to give a sophisticated, factory-installed look.
Compatible with any device that is USB powered, the USB Charger Kit ensures the fastest possible charge rate and tailors the output as needed.
A perfect solution for convenient garage door operation, the control module uses an OEM circuit board that is compatible with almost all modern garage door openers.
