hello .. I have problems with the Passat 2.0 TDI 3c. 2006th I got a report that my EGR valve does not work, so I bought new and replaced. Problems are not finished, because the car every 5 minutes, switch to the factory program and had no power. per minute is automatically moved back to the normal mode is going ok. this is repeated. I wrote below VCDs report! Firstly, when the valve is plugged in and the second is when the valve is unplugged.
EGR valve is an electrical and turned off the car operates normally, except that the flashing light on the numerator
Sunday,21,March,2010,16:02:08:26365
VCDS Version: Release 805.1
Address 01: Engine
Control Module Part Number: 03G 906 021 MR
Component and/or Version: R4 2,0L EDC G000SG 9389
Software Coding: 0000072
Work Shop Code: WSC 47171
1 Fault Found
001027 - EGR Valve (N18): Malfunction
P0403 - 000 - - - MIL ON
Freeze Frame
Fault Status: 11100000
Fault Priority: 1
Fault Frequency: 1
Mileage: 121249 km
Time Indication: 0
Date: 2010.03.21
Time: 16:01:39
Freeze Frame
RPM: 798 /min
Speed: 0.0 km/h
Duty Cycle: 23.1 %
Voltage: 14.21 V
Mass Air / Rev.: 220.0 mg/str
Duty Cycle: 0.8 %
Bin. Bits: 00000000
Readiness: 0 0 0 0 1
Sunday,21,March,2010,16:16:56:26365
Address 01: Engine
1 Fault Found
001031 - EGR Potentiometer (G212): Signal too Low
P0407 - 000 - - - MIL ON
Freeze Frame
Fault Priority: 1
Fault Frequency: 1
Mileage: 121249 km
Time Indication: 0
Date: 2010.03.21
Time: 16:17:07
Freeze Frame
RPM: 819 /min
Speed: 0.0 km/h
Load: 0.0 %
Lambda: -5.9 %
Mass Air / Rev.: 255.0 mg/str
Mass Air / Rev.: 435.0 mg/str
Bin. Bits: 00000000
thx
Igor
Address 01: Engine
1 Fault Found
Freeze Frame
Fault Priority: 1
Fault Frequency: 1
Mileage: 121249 km
Time Indication: 0
Date: 2010.03.21
Time: 16:01:39
Freeze Frame
RPM: 798 /min
Speed: 0.0 km/h
Duty Cycle: 23.1 %
Voltage: 14.21 V
Duty Cycle: 0.8 %
Bin. Bits: 00000000
Address 01: Engine
1 Fault Found
Freeze Frame
Fault Priority: 1
Fault Frequency: 1
Mileage: 121249 km
Time Indication: 0
Date: 2010.03.21
Time: 16:17:07
Freeze Frame
RPM: 819 /min
Speed: 0.0 km/h
Load: 0.0 %
Lambda: -5.9 %
Bin. Bits: 00000000
thx
Igor
