CHECK EM OUT!
The Bilstein PSS9 Suspension enables the user to adjust the vehicle's ride height by adjusting the threaded shock bodies (front) and the threaded rear spring perch (rear). This system features both front coil over and fully adjustable monotube gas pressure shocks with nine levels of performance valving that range from performance street comfort to competition, along with progressive rate coil springs. The PSS9 system lets you set your car low and tight for optimum performance or back to a more stock like ride height and handling characteristics. Ride height adjustments can be made on the vehicle without removing the suspension. The solid aluminum spring seat and lock nut allows a selective adjustment of the vehicle's ride height. Spring travel and vehicle body height change, but the spring seat remains pre-loaded throughout the allowable range of adjustment. The 9 is PSS9 stands for 9 levels of shock dampening adjustment. The front and rear shocks feature a adjustment dial that allows the user to dial in specific dampening adjustments. This is great for preparing a vehicle for street or track use.
Bilstein PSS9 feature:
OEM Porsche Build Quality
9 Way Adjustable Dampening Shock Absorbers
Height Adjustable Coil Over Shocks
Progressive Rate Springs
Complete Mounting Hardware
(2) Wrenched (For Height Adjustment)
Before Bilstien PSS9 Kit (4X4 mode) http://****************.com/smile/emthdown.gif
After Bilstien PSS9 kit! http://****************.com/smile/emthup.gif
Settings range from OEM like ride quality to stiffer. Setting 9 being the softest is identical to the OEM set with 18' wheels.
Applications:
VW MK5 Golf 2.0 FSI
VW MK5 Jetta 2.0 FSI
VW MK5 Jetta 5 Cyl.
VW MK5 Jetta TDI
CLICK HERE FOR MORE INFO!
Complete Set (4) $1,649.00
For a 10% discount use coupon code "vortex10" when ordering online!
BUY-IT-NOW!
-Kyle http://****************.com/smile/emthup.gif
Modified by [email protected] at 11:42 AM 3-13-2006
