I just got a new (to me) MK3 GTI with VR6. The CEL is on and the codes are P0103 (Mass or Volume Air Flow Circ High Input) and P1127 (Long Term Fuel Trim mult.,Bank1 System too Rich). Could these have to do with the aftermarket short ram intake being on the car instead of the stock air intake? If not what else could be triggering the issue?
My other problem is the car leaks out all of the coolant. I can see on the bulb and below it signs of coolant leaking there, and I know I have to replace that, but could ALL of the coolant leak out through the bulb? I'm not talking mostly empty the bulb is completely empty, no coolant whatsoever.
Thanks
~Josh
Thanks
~Josh
