I am asking one of you MK5 R32 owners to please do me a favor if you could. Will you check on your fuse box in the engine compartment if you have a green wire in the front of the box behind the thicker black wires that connects the 3 black wires together? If you look it should be in between the wire's nut and bus bar on three different wires. The easiest one to pinpoint is the wire that connects to the one spot that doesn't have the bus bar and has a little rubber piece instead. All three wires that have this green wire have the rubber piece behind the bus bar.
This will help me out greatly to know if you guys also have this green wire.
THANK YOU! :thumbup::beer:
