Re: engine hesitation under partial load. Ideas? (kflip)
My guess, based on past experience of the same problem...
1. A clogged fuel filter
or
2. A failing fuel pump
If you haven't changed the filter within six months to a year, I'd try that. If you have, it could still be a bad filter and it's worth a try. If that doesn't do it (and you can get it to act up while sitting still), you could have the fuel presure checked to see if it is the pump ($$).
Good luck...
or
Good luck...
