Re: Engine light after spark plug install...more to read (maxt)
Simple to reset - disconnect the battery then follow this procedure to reset the ECU:
1. Turn the car to ON but do not start it (all the dash lights will come on) wait 2 mins.
2. Start the car but do NOT touch the gas - let it idle for 2 mins.
Now just drive as you normally would. You will notice that the car may stumble a couple of times a little bit as the ECU resets and relearns all the engine mappings etc. If you drive the poop out of it for the next few days, the ECU will set the engine fuel and timing curves to the most agressive settings and you may get a touch more performance out of it.
If you ever swap out the stock chip and put in an aftermarket one, this is the same procedure to use. If you still have a check engine light, then you probably forgot to connect something or there really IS something wrong, just FYI.
