1 - 7 of 7 Posts
Hi,
Tomorrow I'm going to help a neighbor and fellow 'Dubber pull and later
replace an engine in a 1990 Jetta w/ 1.8 Digifant and Manual Trans.
Any helpful hints would be welcomed, also advice on replacing parts
on "Used engine" prior to install...New Clutch ?resurface flywheel,
new rear seal...New Belts/timing belt, hoses, Water pump....anything
else????
Thank you... http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif
Re: Engine R & R 1990 Jetta (enigmamachinen)
While engine is out...replace seals (rear main, front crank, cam, intermediate shaft) along with timing belt/tensioner, water pump, check out freeze plugs in rear of block and if they look weak replace them (cheap and ez while engine is out, a betch with it in). CV joints repack/boots? Shift linkage rebush, steering rack adjustments EZ with engine out, room to work! Engine mounts in real good shape...if not now's the time to change em!
[Modified by spitpilot, 2:06 PM 4-9-2002]
Mk4 VR6, Mk2 16v, E30, P71 CVPI
put a new clutch in, too. I recommend a 16v pressure plate. If you know how, the final drive flange oil seals and input shaft oil seals should be done on the trans. If u do the flange seals, go to the dealer and get the 2 thrust washers that go in there (part# 020 409 295). Mine were shattered when I did those seals.
Discussion Starter · #6 ·
.... Gearhead455....Spitilot...fopeano.......Thank you http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif
1 - 7 of 7 Posts
