2.0l GL with a cyl 2 misfire. When driving regularly, the car does just fine. However, if I start in first gear and accelerate as much as I can, the car will occasionally just lose power as if the throttle is closed. This normally only turns into a problem when I reach 5th gear, because even with the pedal all the way to the floor, the car will refuse to accelerate unless I drop to 4th gear, and if I stay in neutral for too long the engine will actually die, so I have to downshift pretty fast without rev-matching. What could this be? I'm kind of upset, with how much work I put into the car, because I really like it, but it just doesn't drive as well as my zetec escort.
recently done work:
head gasket: done myself
timing belt: done by professional
tune-up: done myself
recently done work:
