1 - 5 of 5 Posts
Hello folks.
Wanted more input please. Mk4 Jetta 2.0L.
Recently the transmission mount broke causing engine to twist and hit parts of engine bay. Clutch stalled several times.
After driving to mechanic and having mount repaired, a new rattle emerged. Rattle comes on with moderate to heavy throttle, in neutral and while in gear - manual transmission.
Serpentine belt off - rattle persists
No Check engine lights
Upper engine mounts seem okay
Acceleration is fine, transmission doesn’t appear to slip.
What could this be? Thank you!
Ever figure it out ? I have a rattle that seems like it comes from the valve cover. I put new valve cover gasket and there is a splash guard plate in there . I just put it off as that is what I'm hearing when I rev the engine .
1 - 5 of 5 Posts
