engine swap
541 Views 7 Replies 8 Participants Last post by  turborave
I have a 2001 Jetta4 2.0 8V and I need more power. Is it easy to swap may engine for a 1.8T? I need some tips....
See less See more
1 - 8 of 8 Posts
Re: engine swap (bora-brazil)
Falaê, bro...blz?!
Pô, logo aí em Sampa...passa o bichinho pra álcool, estufa uma turbina cheia de más intenções e comece a rabiscar o chão...
Seriously...keep in touch.
Gigante
See less See more
2
Re: engine swap (hinshu)
Same here...same engine and no power ...btw it's an auto =(
its not that tough if you can do it cheap enough. Usually its cheaper to sell the 8v and buy a new or used 1.8t. You could most likely turbocharge the 2.0 for around the same cost. While people do it all the time with mkii's and mkiii's it is just not economically advantageous at the point in the mkiv's life span.
Re: engine swap (woodrell)
In case ur too lazy to look at the above link
neuspeed has a turboupgrade for 2.0l engines. Might be a possability. says up to 50% hp increase...
See less See more
Re: engine swap (idburns)
quote:[HR][/HR]In case ur too lazy to look at the above link
neuspeed has a turboupgrade for 2.0l engines. Might be a possability. says up to 50% hp increase...[HR][/HR]​
its a supercharger and it bumps the hp of the 2.0 up to about the level of a stock 1.8t
See less See more
1 - 8 of 8 Posts
