1 - 4 of 4 Posts
Does anyone know whats the optium temp of the Oil should be before you nail the loud pedal?!
Also how do you check?!?!
Re: Engine Temp (JettaTxG60)
Not sure about oil temp, but it's usually pretty safe to stomp on it after you've driven around for ~10 minutes -- longer in the winter.
AFAIK, there's no way to check oil temp on Mk4's. If you want that feature, you're stuck installing an aftermarket gauge.
i usually wait until the water temp is up to the operating temperature which is straight up right in the middle of the gauge... it only takes a couple of minutes...
1 - 4 of 4 Posts
