Been that cleaned that!
Go get a can of throttle body cleaner and a can of Mass Air Flow cleaner. remove both from car. follow instructions then once u reinstall maf and tb unhook battery for 15 mins and leave drivers door open it will reset your ecu to relearn tb position basically that code is caused by a dirty tb valve the 2.0 are bad about oil in the intake track it tends to carbon up behind the tb you have to remove it and clean it dont be a dipstick and just spray it in there actually take it off the car. you will be surprised how much crap is in there. it should only take you 30 to take off clean and reinstall dont cheap out and buy brake cleaner. use the right cleaner for the job your doin.
