1 - 2 of 2 Posts
Discussion Starter #1
While i try to open the roof of my eos the message "open rear lock" appears. For some reason the trunc is not released.
Vag-com shows this error.
Address 26: Auto Roof
Control Module Part Number: 1Q0 959 255 B
Component and/or Version: Verdecksteuergeraet 0622
Software Coding: 0655362
Work Shop Code: WSC 30100
 έH
02805 - System Interference
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 233
Mileage: 54700 km
Time Indication: 0
Date: 2000.00.00
Time: 09:02:19
Freeze Frame:
Voltage: 11.60 V
Voltage: 11.50 V
Voltage: 4.90 V
Error Code: 12
Any help?
Re: Eos roof stops. "Open rear lock" error message (apostolis)
I suggest you take it to a trained technician, the EOS roof is too complicated to work on yourself and requires several special tools which are quite expensive.
1 - 2 of 2 Posts
