Hi All,
I've had an intermittent EPC light get thrown a couple times over the last few months, 2016 GTI SE DSG nonPP. It's extremely random when it comes on. And will usually reset itself with a quick engine restart. I plugged in my VCDS cable and got codes for an overboost situation. I know this can be common with some MK7's but I wanted to see if anyone ran into this issue themselves and how they resolved it. The light only comes on after a cold start, but under any load. If the oil is up to a readable temp it wont trigger. And it's even random if the cold start triggers the EPC light. I have some mods, but I don't think they would cause the light, especially since the first time it happened was before the mods. Right now its just a Turbo Inlet Pipe, Turbo Muffler Delete, and K&N filter. Again nothing crazy that should cause an overboost any more than the stock parts. The vehicle is still under a CPO warranty, I'd probably have to switch the stock parts back on before bringing it in. But I wanted to see if there are any DIY fixes for the stuck wastegate actuator. Also VCDS log below
15202 - Actuator Module for Turbocharger 1
P00AF 00 [104] - Stuck
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 4
Mileage: 57802 km
Date: 2020.02.08
Time: 11:50:57
Engine speed: 2158.75 /min
Normed load value: 40.8 %
Vehicle speed: 30 km/h
Coolant temperature: 50 °C
Intake air temperature: 15 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 13.925 V
Unlearning counter according OBD: 40
Status of charge air pressure control valve basic setting-LV_BPA_AD_REQ[0]: 00000000
Charge air pressure control valve uncond voltage sensor: 2.5830 V
Charge air pressure control valve position: target value: 99.99 %
Charge air pressure control valve position: actual value: 35.31 %
Charge air pressure control valve activation pulse duty factor: 83.12 %
Charge air pressure control valve voltage: position closed: 3.6426 V
STATE_BPA[0]: OPM
