1 - 4 of 4 Posts
so my car went off the other day and the epc light came up and then the car went into limp mode.....read all the threads on here and i have tried almost everything but nothing seems to work.... about to give up and just sell the car for what ever i can get just spent 350 bucks at the stealership replacing the coil pack and the spark plugs and it made things even worse now it cuts off and wont come back on untill the battery is almost flat...as anyone ever had the same problem and got it fixed if so plz advice...and yea its a 2002 a4 1.8t with absolutely no mods......thanks in advance
Re: EPC PLZ HELP (sangololu)
we'll need more than that to help you. you should get the car scanned with vag-com and then the problem will be apparent. without that there's not much we can tell you.
try your regionals to find someone with vag-com.
Re: EPC PLZ HELP (Better Thomas)
thanks for the response ....just got back from autozone and the code that came up read
P0171 too lean (bank 1)
and yes i already checked for vacum leaks found one which i fixed but problem keeps comming back
1 - 4 of 4 Posts
