[email protected]: can u help?
513 Views 3 Replies 2 Participants Last post by  TurboDave18t
Hi! I had posted a topic about rims on another msg board and someone had replied saying that I should talk to you and ask the same questions. I want these rims on my 00 VW NB --> http://forums.vwvortex.com/zerothread?id=236653
but they are 17X8 and he says the OEM VW 17s are 17X7 so he said i should be careful.
I dont understand what the difference is between a 7 and an 8?
How could it hurt my car?
If you could help me out with this it would be greatly appreciated. Thanks!
[Modified by DubLicious, 3:57 PM 2-9-2002]
1 - 4 of 4 Posts
Re: [email protected]: can u help? (DubLicious)
I'll fill in for Eric for now
The 17x7's are 17 inches in circumference and 7 inches wide. The 17x8's are 8 inches wide.
The only difference is the width and weight. A wider wheel requires wider tires, but the stock size of 225/45/17 shouldn't have any problems with an 8" wide wheel.
See less See more
Re: [email protected]: can u help? (TurboDave18t)
thanks for that info. but my main concern is... is it going to rub when i get my car dropped 60mm? since now im going to have bigger wheels and wider tires... or am i good to go?
[Modified by DubLicious, 6:36 PM 2-9-2002]
I would say you are probably fine, but I am not sure.
bumping this back up for someone else to confirm
See less See more
1 - 4 of 4 Posts
