Re: Euro Badging (JWHITE)
I would recommend measuring from the seam on the trunk lid and the edge of trunk. Then use tape to mark a level horizontal line and another piece of tape as the vertical edge. That way, when you place the badge, you can look through the clear "window" that holds the badge together once you remove the piece off the sticky backing, and looking through the window, you can line up the badge with the two tape lines. Remove the tape, and your done, and correctly positioned.
