Just installed a Euro Customs Stage 2 tune on my 2001 Jetta 1.8t 5spd. Went for a test drive, stuttering from 2-4k and backfiring when shifting above 2.5/3k. CEL popped so i went to AutoZone and got it read. Main code came back as P0103 with 2 secondary codes being P0343 and P0237. Realized I failed to put washers in my DV as instructed for the higher boost, so I went home did that. Unplugged my battery attempting to clear the code (didn't work) and went for another test drive about 7/8 miles and came back. The stuttering and backfiring was still happening. And now my car will sometimes start and sometimes not. Unplugging the MAF didn't really help with it not starting. I have yet to test drive my car with the MAF unplugged as I don't know if it is wise to do so. Also the ASR/TC light will sometimes pop on and sometimes not. My car has a RKX Precision DV (Not hybrid or any going to the atmosphere), and a K&N cone filter. Any help? All i can think to do is get some MAF cleaner
EDIT: I will be going to a local euro shop to get them to read my car with VCDS and most likely a smoke test to rule out any air leaks.
