1 - 11 of 11 Posts
Discussion Starter · #2 ·
Re: euro h4 headlight adjuster (hybrid gti 2)
if it matters. the light is drivers side and it's the upper oneon the right as you look at it. the front plastic part has busted that holds the lamp in place.
bump
no one know what i am talking about or what? got a 92 gti adjuster but was all wrong
Re: euro h4 headlight adjuster (Batan)
Heres 2 adjusters and 1 swivle part #s
Description as looking at the lamps head on.
DOT version
1GM 941 133 (top left)
1GM 941 141 (top right)
1GM 941 141A (bottom left)
E-code
191 941 133 (top left)
191 941 141 top right)
191 941 141 (bottom left w/o leveling motor)
191 941 297 (bottom left w/ leveling motor)
Discussion Starter · #8 ·
Re: euro h4 headlight adjuster (Eric D)
interesting also do you happen to know that part numbers on 12, 9, 13? for the city lights
#9 is 191 941 669A SOCKET FOR BULB
#12 is N 017 717 2 BULB HL12V4W
#13 is 357 972 752 FLAT CONTACT HOUSING 2 PIN
Leveling motors mounted on the lamps. The motors in this pic are mounted incorrectly, they should be up behind the lamp.
I have the motors and switch waiting for my 7" HID projector mod.
These motors are very pricey if bought new, easly $500 for 2 motors and the dash switch would also require 2 adjusters and the wiring harness or matching plugs (sold separately). Used is the way to go.
Discussion Starter · #11 ·
WOWCH! just a bit pricy on them motors. ok cool thanx for the city light parts. is there any special wire harness i need for them?
thanx
1 - 11 of 11 Posts
