Re: Euro lights -- no high beams (Blown6T)
If the person wired them correctly, they should have intalled a fuse inline for the high beams, maybe see if you can trace it down.
Also, the relays are under the dash w/the fuse box?? The only way I have ever seen them run is with the relays in the front/under the hood. It basically breaksdown like this: there are 4 wires on each relay
-power
-trigger (from old headlight wires/switch to relay)
-ground
-wire to the headlight
Try tracing the wires and make sure they are all hooked up. And see if there is a fuse inline somewhere going to the relay (there should be). It just depends on what type/set-up the PO used for the harness.
BTW, you probably won't find Kris (KinetikSLC in this forum, try the C)
