euro switch
646 Views 13 Replies 6 Participants Last post by  blkjettavr6
just put my euro switch in and should i be able to turn just the parking lights on with the fogs on with no headlights? if i should be able to then mine is broken or something.....thanks
1 - 14 of 14 Posts
Re: euro switch (blkjettavr6)
the switch should let you do that. there are three main positions, plus fog lights.
first position is off/dtrl, second is parking/city lights, third is low beams on. pulling out on either the second or third position turns on the fogs.
the switch also comes with a jumper, that lets you turn on your highs and lows at the same time.
-tom
Re: euro switch (corduroy79)
well my fogs dont come on with my parking lights on...the little green light that lights up when you turn on your fogs doesn't even turn on. what do you think the problem is?
sounds like the switch itself is busted, but im really not that sure...
-tom
Did a jumper come with your set?
If you put the jumper in then......
You can have parking while having fogs on
AND......your DO fogs stay on when you flip the high beams.
Thanks to Mike at Potters for the heads up..... http://****************.com/smile/emthup.gif
See less See more
Re: euro switch (DUHSHET)
mine didn't come with a jumper set!? i bought the switch from someone on the tex. what is the jumper and what does it look like and where can i get one? thanks!
[Modified by blkjettavr6, 8:40 PM 2-11-2002]
It's a bent piece of metal that fits into two slots in your relay panel. Call Potterman, they can probably help you.
T.C.
Re: euro switch (collins_tc)
i thought the jumper only lets the highs and lows go on at the same time?
There is a separate jumper that allows you to run fogs without headlights, and also another that allows highs and lows at the same time.
If you wish to disable DRLs, you must disconnect a cable behind relay 173...follow the back of it, and you'll find a yellow plug.
Re: euro switch (SiDeeFung)
quote:[HR][/HR]There is a separate jumper that allows you to run fogs without headlights, and also another that allows highs and lows at the same time.[HR][/HR]​
Well Mike at Potters said that it is the same jumper. You should call him and make sure your self. He told me that "other"jumper is added.....youll fry your system. That jumper is supposed to do both.
But hey....that's all I did and they are doing exactly what he said they would.
just emailed him...anyone know how much it is going to cost?
no one know how much it is going to cost?
when u pull out 173 it looks like this
_1__ __2__
_3__ __4__
_5__ __6__
i forget what does what but if u connect 3/4 and 2/6 u get fogs/high/low.
Re: euro switch (JimGTIVR6)
quote:[HR][/HR]when u pull out 173 it looks like this
_1__ __2__
_3__ __4__
_5__ __6__
i forget what does what but if u connect 3/4 and 2/6 u get fogs/high/low. [HR][/HR]​
what!?
1 - 14 of 14 Posts
